Copy & Paste features?
Is it possible to copy and paste features? In CATIA I can make a feature and then cut and paste the feature. Then I go back and adjust the values and possibly the inputs. I can quickly build up a model. Is this possible in OnShape?
5
It is not, but it should be.
It is also handy to copy feature and supress original if you need to test different values but keep the original untouched.
And because we are talking about Onshape, this could work also between documents.
