Default export formats
michael3424
Member Posts: 758 ✭✭✭✭
I've probably asked about this before, but how difficult would it be for the Onshape developers to let the user select default export formats, both file type and relevant features. I export in STEP format for parts that will be machined and in STL format for parts that will be 3D printed and the latter is especially annoying because the format not only needs to be changed from Parasolid to STL, but to also select mm and fine resolution. It would be great if Onshape could remember the last format and features I used for an export and default to them the next time.
3
Most of the times it is required when multiple files in exactly same format need to export.
