Importing DWG as base sketch
brian_rupp
OS Professional Posts: 13 PRO
I try importing a DWG and I can view it but I can't use it as a base sketch for a new part in Onshape. Anyone successful at this yet?
jakeramsley
Member, Moderator, Onshape Employees, Developers, csevp Posts: 669
Hello brian_rupp,
When you upload a .dxf file to your document, you can place it in a sketch with the 'Insert DXF or DWG' tool. While in a sketch, click on the 'Insert DXF or DWG' button and choose the dxf you want to import. This will come in with no constraints.
Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com8
A possibility of automatic constraining or dimensioning an existing sketch would be really useful in such situations. Is there a tool for this in Onshape? I can't find anything. I know you can always fix each line to a current position, but sometimes I'd like to have some flexibility with it...
Twitter: @bradleysauln
