How to define and use simple custom design check rules?
giulio_tamberi
Member Posts: 3 ✭
Is there a way to define and use at least simple design rules to check my model against?
For instance, it would be beneficial to define a few rules like the following ones (with an example for the limit values):
And then check the model and see any non compliance to these rules highlighted in red or yellow in the design part.
Thanks,
Giulio
- minimum wall thickness = 0.1 mm
- minimum embossed detail (high) = 0.6mm
- minimum embossed detail (width) = 0.6mm
- minimum engraved detail (high) = 0.6mm
- minimum engraved detail (width) = 0.6mm
- minimum clearance (between any two walls, wires, or separate parts) = 0.6mm
- minimum wire width (a wire is a feature whose length is greater than two times its width) = 2mm
Thanks,
Giulio
Narayan_K
Member Posts: 379 ✭✭✭
@ giulio_tamberi , At present Onshape don't such evaluations options.
6
