STL export into Vectric Cut3D
On opening an STL model generated by Onshape in Cut3D it appears as it should. When I generate a cutting path it seems to take much longer than something similar I've generated from Openscad and the estimated time to cut is much longer. When I preview the cutting, it generates a wrong result, it is lower on one side than it should be. I have tried the different settings from fine to coarse with the same result.I don't know whether this is an Onshape or a Cut3D problem, my Openscad STL files didn't have this problem. Has anybody else had this problem with STL or Cut3D.
joe_dunne Onshape Employees, Developers, csevp Posts: 198
Hey David,
Might I recommend you try Kiri:moto? You can find it in the App Store. It looks pretty close to what Cut3D offers. The only big difference I see is the 2 sided cuts.
Kiri:moto is free
I cut all kinds of parts with it on my CNC.
Joe Dunne / Onshape, Inc.5
When it is first opened.
When the cutting has been done in the preview. The right hand side is the same height as the front of the inner cutout.
Kiri:moto is free
