Deleting shared documents
nyholku
Member Posts: 60 PRO
Hi,
I'm still on the Free Plan to investigate and learn OnShape.
Now the document page says I've used up 10/10 private documents though I only have 8. I also have two shared documents which I guess are counted towards the 10 private documents.
And now I would like to delete those shared documents (they are/were not created by me). But I can't figure out how to do that!
If I select a shared document and click on the cog wheel icon the menu does not have delete or unshare or anything useful....feeling rather stupid as this surely must be a simple operation.
Narayan_K
Member Posts: 379 ✭✭✭
Because they are public document.so you are not able to delete or Unshare.These two will not count under private document.kustaa_2 said:Hi,
Can you please check the trash? If you any document in trash which is deleted before will also be counted.
5
