Import Pack and GO Option
OS Professional, Developers Posts: 17 ✭✭
edited June 2016 in Using Onshape
I was used to Solidworks. So sometimes I import my SW assay.
I think this option is needed.
Now we have two option "Imported models are in 'Y Axis Up' coordinates" and "Import file to Part Studios only(flatten)".
How about this option "to create part studio for each part on Import."?
  • Member Posts: 379 ✭✭✭
    @ song_jaybi , If you have zip file which created from solid works by zip and go option.then you can Import that zip file in to Onshape. so that all the part will be imported to new part studios.
  • OS Professional, Developers Posts: 17 ✭✭
    I want to import separately part studios.
    @ song_jaybi, sorry for the confusion , what i mean is you can get the parts and sub-assemblies you used to create that part will be in separate part studio.
    For example.if your main assembly contains 2 sub-assemblies and 3 parts.then after uploading you will get 3 assembly tabs(2 sub-assemblies and 1 main assembly) and 3 part studio.
  • Member, Developers Posts: 619 ✭✭✭✭
    edited June 2016
    @song_jaybi, kindly refer below information which is taken from Onshape help document. It will help to clear all your doubt regarding Importing of CAD files.
    Processing CAD files
    When Onshape recognizes an imported file as a CAD file (based on its file extension), Onshape automatically presents processing options. You can also choose to export to another format from a context menu for an entire Part Studio (including hidden parts), or for a particular part selected from the parts list. Onshape checks a zip file for supported assembly files with the same name as the zip file. When zipping assembly files for import into Onshape, you can zip the files individually, or zip an entire directory. Keep in mind that when zipping an entire directory, the zip file must have the same name as the assembly (minus the extension) and you must not rename the zip file.
    For more information, see Exporting Files.
    When importing a CAD file, you have the following processing options:
    • Imported models are in 'Y Axis Up' coordinates - If the file was created in a system that orients with Y Axis Up, the models would by default be brought into Onshape (a Z axis up system) with a flipped coordinate system. Check this box to reorient the axis system to match Onshape and display the model with the coordinates you expect.
    • Import file to Part Studios only (flatten) - If the file is an assembly, or contains an assembly, you have the option to import it as only a Part Studio, by selecting the Flatten option. In this case, the assembly is flattened to a set of parts in a Part Studio. There will be duplicate parts created whenever a part is instanced more than once.
    flatten imported assemblies option
    The automatic processing happens only for files that Onshape can translate. All other files are simply imported into a tab.
