detect location of click on face UV
adamohern
Member, OS Professional Posts: 216 PRO
When trimming, for example, many packages detect the user's intent based on click location. For example, if trimming a surface, clicking anywhere on the left half will cause the right half to be removed by the trim operation, and vise verse. The user can then flip the direction manually if necessary.
Can FS do that?
Can FS do that?
ilya_baran
Onshape Employees, Developers, HDM Posts: 1,259
Not today -- the user can instead click on an edge or a vertex to select a side -- evDistance will return uv coordinates on the surface. Having a direct uv input is not a no-brainer because storing uv coordinates as a feature parameter is likely to not be robust to upstream changes. So to support the type of workflow I think you're talking about, I think we'd need a way to convert the data into a more robust form.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc5
