Dimensions tool bar
in Drawings
I can't find ot Dimensions tool bar. Only Sketch tool bar on screen. Please show me how to turn on/off tool bar
The measure tool displays measurements dynamically whenever you select entities.
1) Select any entity. The measure tool show measurements for that entity.2) Select another entity. The measure tool shows measurements between the entities.
You can use the information displayed to enter values elsewhere in the system, for example, as a dimension:
With the Measurement dialog expanded, click and drag to highlight the value you want to copy:
