How to rotate whole assembly?
Hi,
im new with onshape and 3D design in general, I have a made some parts in solidworks and made them into an assembly. I have imported this assembly into onshape.
When i designed this part/assembly I designed it in the orientation which would be easiest for me at the time, but now when i'm going back to change things its getting confusing. I would like to rotate the whole assembly 90 degrees to the right, so that in the current 'front' view the 'bottom' ends up on the 'left'.
Can this be done and set so that i can use the rotating cube in the top right and corner to quickly go to the correct view?
