closed path not creating a face
pierre_grpierre_gr Member Posts: 12 ✭✭
Hi,
I have a simple sketch here https://cad.onshape.com/documents/e1f0909710ab2af754bfa7ce/w/ba81f66e21dfc5e618f0ee92/e/c23f9213da11e626f8ce015a 'Studio part 3' where a closed path doesn't generate a face for extrusion.
Points seems to be connected. I'm not sure to understand where the issue is.
Anyone with a similar issue ?
Thank you,
Pierre
  • Wesley_NWesley_N Member Posts: 17 ✭✭
    What I would do is draw lines across the sketch geometry to help isolate where the open point is.
    http://www.keystonecollections.com/ - Handcrafted Furniture                                   http://www.newswangerpen.com/  - Fine, handcrafted writing instruments
  • pierre_grpierre_gr Member Posts: 12 ✭✭
    Hi,
    I tried and I can find the guilty point but I don't get how to fix it.
    For example, I created another part in the same doc I shared the link to. There is is a simple spline with 2 offsets on both side, joined at their end.
    The first path is closed and a face is created
    The second path is a copy/paste of the first where I only move the end of the spline and the face is not created.
    Any clue ?
    I was playing with it and it does seem like a bug. The only thing I can say is to create a support ticket.
    @pierre_gr, Kindly refer below video in there you can observe open end at both corner of right side. If you close that both end then your problem will solve.
