How to create custom template with custom properties using draftsight as editor
I have followed the tutorial on how to create a custom template, then export it and edit it with a 2D editor and save as a *.dwt.  I downloaded the latest version of draftsight and followed all of the steps, then when I import the newly edited template and create a new drawing using said template I run into issues.......The new drawing is blank, no template, when I click on "sheets" in the upper left corner there are two of them, one titled "Model" and one "Sheet1".  Sheet1 is blank, but MODEL has my template in white on a black screen, as you would see in "model space" when using 2D platforms.  How do I fix this??
  • mark_hatzenbuhlermark_hatzenbuhler Member Posts: 2
    @PeteYodis Thank you VERY much, that was exactly what I needed.  Once again Onshape comes through in a flash, keep up the good work guys.
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 556
    @mark_hatzenbuhler You're very welcome.  We are also working on ways to make this process easier.
