Problem with loading drawings
hansrudolf
Member Posts: 55 ✭✭
Returning to Onshape after some weeks of inactivity, it seems that I cannot load the drawings I did earlier. Just see the rotating arrow for minutes. The same with a new assembly I did yesterday.
Has this something to do with new features introduced June 17th?
Regards, HansR.
Regards, HansR.
philip_thomas
Member, Moderator, Onshape Employees, Developers Posts: 1,381
@hansrudolf - Just a quick sanity check;
1) Are you using a supported browser (chrome, firefox, safari)?
2) Are you running a popup blocker (please allow Onshape or turn it off)?
Many thanks - Philip . . .Philip Thomas - Onshape5
Kind regards, Hansrudolf
There will be a dialog to add a message and an option to share the document with the Onshape team.
As I used Opera since day 1, and never had problems, it seems I have to leave it now. At least for Onshape!
I opened my documents in Firefox and can generate and print drawings as in all the months before.
The feedback also works (if Iwuld need it and remember next time where to find it)
To be honest, I find it a bit sad that Opera is not supported, but that's life.
Sorry for making such troubles.
Kind regards,
Hansrudolf
hmm, maybe someone who knows could submit a request for them to rename those links?
