opDeleteBodies doesn't remove outline
sören_svenssonsören_svensson Member Posts: 22 ✭✭
Hi,
After creating a sketch in FS and (for example) extruding it, I remove the sketch with opDeleteBodies.
However, the outline (edge) of the sketch still remains.
What am I missing here?
You can see it in "Nuts & Bots Generator"
https://cad.onshape.com/documents/318189c1164cb057e78793b0/w/a9de37285f1c4300497923f1/e/7dc3f0e4317cacd3cf7d1863
  • sören_svenssonsören_svensson Member Posts: 22 ✭✭
    Thanks, that fixed it!
    If anyone needs a bearing (ball, roller, needle, conical), you can check out my "Bearing Generator" feature too.
