My documents v Recently opened documents
brian_jordanbrian_jordan Member, Developers Posts: 144 ✭✭✭
As a newcomer to CAD in general and to Onshape in particular I have looked at many documents as part of my learning process. Consequently, when I start Onshape I am presented with a long list of "Recently opened" documents scattered amongst which is a much shorter list of my own creations. I know that I can click on "My documents" to see that shorter list but would quite like to have a configuration option to open "My documents" as the default. Is this possible?
  • jochen333jochen333 OS Professional Posts: 28 PRO
    Vote up for your idea.
    Another thing:
    I would like to delete documents from my Recently List view to clean this list up. Would be helpfuly after a browsing session in public documents.
    But that in the context-menu please!
  • lni64lni64 OS Professional Posts: 38 ✭✭
    +1
    Another thing:
    The flat document list is a mess, a possibility to organize them in folders would be very usefull.
  • cadmandocadmando Member Posts: 68 ✭✭
    +1
    Another one:
    The PS Ass Drawing Tabs on the bottom can get messy, Maybe different colours would help
    edited June 2016
    +1
    I'm also in favor of all the above especially the document flat list. Colored tabs would be alright but I would prefer to be able to consolidate tabs. That is I'd like to be able to create a "folder" tab per say and then insert other tabs into it. Then possibly to even have folder tabs with there contents to be able to be inserted into other folder tabs.
    _Ðave_
  • mlml Member Posts: 53 PRO
    +1 "My documents" as the default
    and additionaly: the actual column sort will be stored. then it is possible to get the list with my custom 'name ascending' instead the ever default 'date descending'
    Drawing Tabs on the bottom: +1
    I've mentioned this already under https://forum.onshape.com/discussion/comment/19016/#Comment_19016  with: stacking the unused picture-tabs into a folder would be useful for more clarity
  • gary_coates645gary_coates645 Member Posts: 7
    +1
    option for "My documents" as the default
    +1 option for "My documents" as the default
