Use angles in sketches
guillaume_2guillaume_2 Member Posts: 3
Hey ev1 !
Does anybody know if is or will be possible to use an angle constraint that could work like the dimension one in skecthes ?
    edited May 2015
    @Guillaume You can use new mate connector and use move to set angle.
    Edit:
    I would like to see angle also in offset for certain mate connectors, but creating new connector is easy so not very high priority on this matter..
  • guillaume_2guillaume_2 Member Posts: 3
    Thank you. I did not see that !
    @3dcad : my question was about scketches, not parts.... unless I misunderstood your message ? Thanks anyway :)
    @Guillaume Ok, I misunderstood your question I thought you were already familiar with the dimension tool and wanted to know how to position parts in similar way.
  • john_michael_robinsonjohn_michael_robinson Member Posts: 1
    I selected the two lines.  However, it is not showing me the angle.
