How to create cross holes on round shaft?
dale_10
Member Posts: 2 ✭
Hi,
I have created a round shaft that needs a cross hole located at a specific location. I can't seem to figure out how to do that. Is there a tutorial I can learn from?
Thank You
Thank You
lougallo
Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015
@dale_10 You will need to create a plane at that point. You can do this a number of ways. The easiest might be just to offset a plane, sketch a point and use the point tool like this:
If you have a point where you want to place the plane you can draw where the tangent plane needs to go like this:
Or you can use on of the Tangent plane FeatureScript tools like this:
In any case, you can then position the exact location of the center of the hole and use either the hole tool (using a vertex) or a circular sketch and cut that way. Hope that helps.Lou Gallo / PD/UX - Support - Community / Onshape, Inc.5
Thank you so very much!!!! This helps me immensely.
