Is it possible to perform a complete copy of a part into the same part studio?
jose_ramon_lopez_blanco
Member Posts: 1 ✭
Dear experts,
Is it possible to perform a complete copy of a part into the same part studio? All features must be independent between the original and copy parts.
I have a bottom part with some holes of different diameters and relative angles. I want to create a full copy of this part to in order to convert it into a top part with different hole angles and diameters. I´ve used Transforms to copy the part, but I can´t make such modifications to both parts independently.
Thanks a lot for your help!
brucebartlett
Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
Not posible in the same part studio.
Would it be helpful to use the transform tool then use some direct editing mods to get the new top part. Move face could rotate to the new angle and change size of hole's while retaining the link to the first part. You can also delete faces and change fillet radius's.5
