Maximum dimensions
Member Posts: 1
What are the maximum dimensions allowed in Onshape? I experience problems when numbers above e.g. 1000 inches are used.
  • Member Posts: 379 ✭✭✭
    @ helmut_frik ,
    as per Onshape instruction Sketch limit was 39370 in and extrude limit 19685 in
    @Onshape support, I have tried to put a value which is less than max limit,It showed me a error message like "
    This operation can not complete because it creates geometry that is beyond the system limit."
    Is it a bug ?
  • Member Posts: 67 ✭✭✭
    edited July 2016
    My state of knowledge is:
    This is a restriction of the Parasolid kernel, wich effects all Parasolid based CAD systems (Onshape, Solid Edge, SolidWorks, NX, etc.). The geometrie of a part is limited to a DesignCube (Parasolid box) which is defined +500m and -500m in all 3 direction from the origin. So the maximum length of a part is 1km.
