Loft with two helix as guides
Hello
I cannot figure out why the loft function is not working between two rectangles linked by two guides. These two guides are 2 Helix on one cylinder and one cone.
Any hint ?
Thanks.
link :https://cad.onshape.com/documents/222ab969059100e7553483e5/w/5b1f616ae80e552e159ad47b/e/1a3ada42250135a48b6cf80c
Any hint ?
Thanks.
I am not seeing that -- can make a copy fine. Please file a support ticket if you see such weirdness.
https://cad.onshape.com/documents/5791360ae4b02dc672bd6227/w/6ce0e0871423b9c2ba9d3fb0/e/86ff37a636076790310b3d62
- the file "test" on which I made the drawings seems quite weird as it size is 110Mo whereas it contains basic shapes, it looks like a corrupted file as you were not able to make a copy.
- regarding the loft creation, my wish is to create a solid, i'll try again by applying your advice (one guide curve per profile point)
