Ball Mate or any mate wont select surface of ball only middle
Hello All,
Im trying to create a simple ball mate. The only problem I can't select the surface of the ball only the middle. What can be cause this issue? I have tried for the past hour but no dice.
Thanks
Thanks
Here is the image of the ball and the only two points it allows me to select.
You use the ball mate to rotate about the central point.
If you don't have an exact half-circle for the socket you can place a mate connector specifically where you need it in the part studio.
Twitter: @bradleysauln
Howdy.
That's odd. Looking at the help file it would appear to be on the end.
https://cad.onshape.com/help/#mate-ball.htm?Highlight=ball mate
Cheers,
Owen S
