set points coincident
mlml Member Posts: 53 PRO
edited July 2016 in Community Support
while not satisfied with the dxf import: https://forum.onshape.com/discussion/4356/imported-dxf-problems#latest
i would like to try it with a featurescript solution: https://cad.onshape.com/documents/150b4b8582755bae310054ab/w/e7f86ea4d976b93e892239e1/e/ae4e6be500f0024054ffe3f8
first, why will the sketch entities disappears after closing the box - the script does not anything?
would be nice if anyone could give me some hints for the questions in the action part. could not find a good entry point.
// get start and end point coordinates
// calculate the distances: start1 - start2, start1 - end2, end1 - start2, end1 - end2
// if one is smaller than range
// set them coincident on the sketch
thanks in advance
ps: never get a category filter to select - even now in edit mode - so it is at the wrong place. sorry for that
  • dave_cowdendave_cowden Member, Developers Posts: 484 ✭✭✭
    @ml I've tackled this problem already-- and I've got some cool tools that ease the pain. PM me and we can talk more about what you're trying to do.
    I ran into this problem importing 1300 or so AISC drawings, and 1000k 8020 DXF drawings ( many of which were riddled with issues).  Now they are all clean, as you can see in these two featurescripts:
    https://cad.onshape.com/documents/ccf713ca7463aeb3cbebce26/w/98577b0c5518f6fa1d06d69b/e/05fed5e3fd0d0ef69021b468
    https://cad.onshape.com/documents/b66d1ff63684957c167272d8/w/2ac42f22fbfa9366e2f4df35/e/33b8950d87918aefcb267a4f
    I can help you as well with your project.
  • mlml Member Posts: 53 PRO
    @dave_cowden thank you for your replay.
    in the meantime i was able with a featurescript to detect the points to set coincident - see original link above to the document.
    now i need an input how to set them coincident in featurescript.
    or, a featurescript that do this and allready exists. importing a dxf into a new sketch would also be fine.
    are you willing to share yours, or a stripped version?
    thanks
    @ml my code isn't Featurescript, it's actually python that generates clean and compact  Featurescript by parsing dxf files.
    If you are interested, PM me some sample drawings, and I will convert them and you can see how you like them.
    The input is a bunch of dxf files, the output is a Featurescript that allows you to choose one of them by name and use it to extrude or cut or whatever.
