How can I add my imported STEP part to an assembly?
benjamin_pelletier
                    Member Posts: 2 ✭
                    I'm designing a play structure and I want to see how it's going to look in relation to my house and yard.  I modeled the house as a set of standard OS parts, but the yard itself is sloped and uneven and doesn't lend itself to OS-style modeling (as far as I know).  I have a 3D surface mesh of my yard generated from some drone images that I've managed to convert to an enormous 8 MB STEP file (there are only 10k faces) which I've successfully(?) imported into Onshape (I can see the 3D mesh in Part Studio and rotate it around and such).  However, when I try to insert it in my assembly, it's not listed among the parts I can insert.
So, how can I add my imported mesh object to my house+structure+yard assembly to see how things are going to look?
viru
                            Member, Developers Posts: 619 ✭✭✭✭
                    @benjamin_pelletier, Currently this facility is not available in Onshape. You can vote for this improvement request which is already raised by some other user. Please vote for this improvement request by visiting below link.
https://forum.onshape.com/discussion/1358/import-surfaces-into-assemblies
Workaround:- Surfaces are not yet supported in assemblies. Perform a thicken on the surface to get a part will definitely work for you.
5
