How can I add my imported STEP part to an assembly?
I'm designing a play structure and I want to see how it's going to look in relation to my house and yard.  I modeled the house as a set of standard OS parts, but the yard itself is sloped and uneven and doesn't lend itself to OS-style modeling (as far as I know).  I have a 3D surface mesh of my yard generated from some drone images that I've managed to convert to an enormous 8 MB STEP file (there are only 10k faces) which I've successfully(?) imported into Onshape (I can see the 3D mesh in Part Studio and rotate it around and such).  However, when I try to insert it in my assembly, it's not listed among the parts I can insert.
So, how can I add my imported mesh object to my house+structure+yard assembly to see how things are going to look?
  • Narayan_KNarayan_K Member Posts: 379 ✭✭✭
    @ benjamin_pelletier,At this stage we can't insert surface to assembly.So you can thicken your surfaces of yard so that it can form a part.now you can insert that part to assembly.
  • SquidLordSquidLord Member Posts: 16 ✭✭
    Also, you're not going to have much use from that surface mesh without reference geometry defining what "level" is anyway, so I suggest using Your Favourite Mesh Tool(TM) to make the surface define the top part of a broken rectangular prism/cube, with the bottom face representing "level." This gets you a volume to import to OS for the rest of the geometry to work off of as well as makes sure you have a stable and static reference frame.
