Importing Solidwork Files Assembly issue
allen_stewartallen_stewart Member Posts: 32
Hello All,
I uploaded the solid work file and it is displayed in my parts studio.  When I try to insert it into my assembly the part isn't displayed.   I noticed that the Solidworks part is comprised of a bunch of surfaces.  Is there any way to convert the surfaces to a solid part?  Thank you
    @allen_stewart,Currently this facility is not available in Onshape. You can vote for this improvement request which is already raised by some other user. Please vote for this improvement request by visiting below link.
    https://forum.onshape.com/discussion/1358/import-surfaces-into-assemblies
    Workaround:- Surfaces are not yet supported in assemblies. Perform a thicken on the surface to get a part will definitely work for you.
  • allen_stewartallen_stewart Member Posts: 32
    thank you for the info.
    Flow up question, when I thicken all the surfaces it generates new parts.  I have over 120 parts.  Is there a quick way to group them together?  I would like to move the object as a whole in the assembly.
  • noanoa Onshape Employees, Developers Posts: 141
    If the solids are intersecting you can use the Boolean tool and Union them together to create a single part.
    Noa Flaherty / Customer Success / Onshape Inc.
  • Narayan_KNarayan_K Member Posts: 379 ✭✭✭
    @ allen_stewart , If you don't want to make them as single part,Insert entire part studio to an assembly tab and apply group constrain as below,
    Did know the group function was there.  Thank you!
    Correct "Did not"
