Purge Recently Opened
lonnie_1lonnie_1 Member Posts: 36 ✭✭
Is there any way to purge the recently opened list?  I opened some public documents to look and would like to no longer see them in the recently opened list.  I would prefer to just see mine.
Thank you.
  • rbaekrbaek Moderator, Onshape Employees, Developers Posts: 77
    You can check the "Created by me" filter. It should by default by sorted by the last modified date and time.
    edited August 2016
    +1 for being able to remove/forget instances from recents list. The most annoying thing with public docs is that they stay there as long as someone is accessing them even though you just took a onetime sneak peak..
    Recents is perfect list for 'currently important' documents, I have actually begun to avoid opening any public links from forum not to mess my list at work. Or if I really wan't to see some interesting but not work related document, I use my personal account for those..
  • stg434stg434 Member Posts: 21 PRO
    I too have been avoiding opening public links for the same reason.  I know OS has many, many, many things on their 'to do' list but being able to clear the Recently Opened list seems like a trivial improvement to include...maybe that's why it hasn't been done yet.
  • lonnie_1lonnie_1 Member Posts: 36 ✭✭
    Glad to see I am not the only one.   :)   I was hoping it was a setting I was missing but sounds like it is not possible at this time.
    It is not currently possibel and I have also discussed this matter with Lou from Onshape. I'm sure at some point we will see this improvement too.
