Importing Solidwork Files Assembly issue
Hello All,
I uploaded the solid work file and it is displayed in my parts studio. When I try to insert it into my assembly the part isn't displayed. I noticed that the Solidworks part is comprised of a bunch of surfaces. Is there any way to convert the surfaces to a solid part? Thank you
https://forum.onshape.com/discussion/1358/import-surfaces-into-assemblies
Workaround:- Surfaces are not yet supported in assemblies. Perform a thicken on the surface to get a part will definitely work for you.
