How to rotate text?
Reuben_Abraham
Member Posts: 6 ✭
I seem to have a problem with the text from the sketches in onshape, as the box enclosing the text keeps defaulting to one position. Any ideas on how to fix this?
viru
Member, Developers Posts: 619 ✭✭✭✭
Reuben_Abraham ,You can rotate text in Onshape sketch by two method.
1st Method:- You have to delete horizontal constraint in text and give dimension to one point after that you can rotate text. Kindly refer below video for more detail.
2nd method:- There is a tool "transform" in the sketch , you can rotate the text with it
8
