Needing to keep both the intersect extrude and the base part...
In the original sketch 1 there is a geometric shape that was intended to be extruded and used when the shape of the complete part was final. The challenge currently is the inability to extrude intersect the compression fitting from the sketch 1 and then retain the complete base part as well as the fitting component. Not sure if I am explaining correctly. I need to extrude intersect a sub component and use both parts when complete. Currently when I finish the extrude intersect function I lose the remaining geometry thus rendering the objective lost. I know this is a bit of a process determining the sequence, however I thought method would yield the best results. I may be wrong with that assessment.
https://cad.onshape.com/documents/ef928c323d0d23263b35037a/w/c712011c38254cc57623122b/e/58e16c97e888c92ef20edc82
The link returns:- "Failed to load document for workspace. Resource does not exist, or you do not have permission to access it"
Owen S
Sorry about that...
And BTW, your document is shared as view only, so no one is able to make a copy of it to experiement/work with.
