Dimensions
I'm not dimensional technician, or a cad user on the whole, but in the absence of such, I've been given the task. Basically, I need to determine the position of a hole, and the radii, on an iges file we have been sent. Our tool maker, who used previous software, we no longer have, says he needs the intersections, and centres of each hole, from the datum line? I've attached a small section of the drawing to show you what I'm seeing. Sorry I can't be more specific, but as I stated, I'm not a CAD expert.
Sounds doable. First import iges to make solid part then make drawing from it showing the dimensions you're after.
If the contents aren't sensitive then if you make something public I'm sure you'd get some help here if you need it.
Cheers, Owen S.
In OS we have sketches and drawings.
Sketches are created to drive geometry and build things.
Drawings are derived from parts and have the measure tools we want to be able to take your part and spit out it's dimensions.
You have to tell the drawing which features you want to measure, but it'll work out the sizes for you.
Hope that helps,
To create part you have to thicken the surface.
