video of creating an internal thread
ray_brown
Member Posts: 3 ✭
g'day all. i'm trying to create an internal thread in a tube to act as an extension join. i've read forum instructions but find them confusing. i'm a visual monkey see monkey do type and have watched creating external threads with ease.
has anyone done a video on creating an internal thread if so is there a link, and if not, could someone please do one for people like myself who learn/understand quicker via video tutorial.
sincere thanks in advance.
ray
ray
Once drawings have the ability to automatically populate dimensions and notes from the model's sketch dimensions and features (hopefully soon) then the threaded holes and cosmetic threads should be all you need 99% of the time.
what i did was create a 23mm thick rod with a 22mm 1.5mm pitch thread each end. i 3d printed that with no problems and that screwed into the end of a piece of aluminium round with a 22mm internal thread.
i then created a 23mm rod with a 20.5mm hole and created a helix, 1.5mm pitch with new sketch and then did the sweep. it worked. i 3d printed that and the 2 pieces screwed together nicely.
i will get some pics when possible.
cheers.
