Mate curves surface to vertical planar edge using planes
I am trying to mate an edge at the end of a curved surface to a vertical planar face, i use solid works for a living and would in this case create a plane in one part and then mate that to the other part vertical surface, easy, but in on shape i can create a plane on the part where i want to mate it, but then when i go into the assy the planes are not visible, i have tried mate connectors and tangents but they don't give me the result i need, is there a way to use the parts planes to mate them together as i can't see a way, or a way of mating an edge with a face. Thanks for any help in advance.
In solid works i can also use sketched from parts to mate them, i assume thats not possible in onshape
I have also considered measuring the distance between the parts and moving them but i can't get an xyz measurement only minimum distance then i could measure and move and fix the parts, not the best practice and not what i would do professional but could be a work round.
Thanks
Thanks
https://cad.onshape.com/documents/57acd725e4b0bdfaaebf6e51/w/46599b456afc095f88a03ff4/e/046aa42cfdc42e42d92fe876
In Part studios, define a mate connector belonging to each part positioned so you can then mate them in assembly. Though if you're designing a case for the iPhone, you'll have a much easier time if you design the case in the same part studio the iPhone is in, directly around the iPhone--this is one of the things Onshape does better than every other CAD program I've used.
Also, I found your document okay, but please link public documents if you're sharing them in the Forums.
thanks for the help though, i do appreciate it.
When you talk about having the parts in the same part studio are you talking about derived parts, still new to this, in solid works i would just bring both parts into a new assembly, i am still thinking the way i work with solid works though.
Thanks again
The closest analog in Solidworks is directly defining a part in assembly.
If you want to see how I defined the mate connectors, make a copy of the document I linked in my previous post, and then you'll be able to double-click on any features to see how they were defined.
