Circular feature pattern not working as expected
david_fisher031david_fisher031 Member Posts: 24 ✭✭
I am trying to get an axis to transform my gears around. I used a circular pattern to create copies of the gear parts but when I try to do the same using a circular feature pattern for a line construction it doesn't pattern as I would expect, being much nearer to the axis than the feature I am trying to pattern. I have tried to replicate this in a simpler example but can't.
Here is the model it is Circular Pattern 2 that I am referring to.
https://cad.onshape.com/documents/57b06da9e4b0f8ff2a92134e/w/ac5aeb414bf9e2c16fc21890/e/d458883e10045907e819d885
  • david_fisher031david_fisher031 Member Posts: 24 ✭✭
    >I think you mean Circular Pattern 3 (not 2).
    Yes you are correct, sorry for getting that wrong.
    > However, this isn't very robust, since it will only work as long as the axis you're patterning around goes through the origin.
    It should work for me in this instance anyway.
    >Patterning sketches seems to be quite tricky.  :-)
    Yes, and to remember that you're patterning a sketch rather than just a feature.
    Thanks for taking the time to answer my question :-)
