Best method to use Mirror
charles_harris178
Member Posts: 15 ✭✭
I have a extruded rectangle to represent a railroad car. Also made into a shell. Used end view to give the shape. Full end view not 1/2 end view.
I want to place windows on one side only, and use mirror for the second side.
Should I place a vertical line at midpoint and delete one half lengthwise of the sketch?
Is this the best way to achieve each side being the same with windows?
owen_sparks
Member, Developers Posts: 2,660 PRO
I'd probably just model half the carriage and then mirror the whole thing to make it whole.
HWM-Water Ltd5
