Pattern Issue
walt_j1
Member Posts: 5 ✭
I created a part with a pattern of bodies within it. I used this part for an assembly. Going back in forth from the assembly to the part and making dimensional changes worked fine. BUT, when I edited the number of instances of the body in the part, then went back to the assembly, the updated instance(s) is not shown. Is there a problem with my workflow or is this a software limitation?
Thanks
Thanks
I suspect what is happening is when you go from 4 to 2 the other two instances have an error and disappear from graphics view.
