Improvements to Onshape - August 23rd, 2016
NeilCooke
Moderator, Onshape Employees Posts: 5,395
There's a ton of really cool stuff in this latest update! Please watch the videos and then take a moment to try out these new features and improvements and let us know what you think!
We hope you enjoy using these new features - as always, all feedback is welcome. Waiting for a particular new feature? Please use the Feedback tool to request it - we're already hard at work on the next round of updates for you!
Remember: The updates listed here are now live for all users when creating new documents and over the next few days these features will also be available in documents created before the date of this update.
FILTERS, LABELS, AND LIKES
The Document filters on the left-hand side of the Documents page can now be used to filter your search results, labels can be applied by dragging and dropping Documents, and Public Documents can now be rated and sorted based on the number of likes, links, and copies.PROFILE IMAGE AND TEAM/COMPANY SEARCH
You can now add an image as part of your profile. This image will display anywhere your name or social cue icon would normally appear - in the top right corner of Onshape, in Teams and Companies, in the Share dialog, and in Comments. A new search field has also been added to Teams and Companies to locate a user faster.TAB FOLDERS
You can now organize your tabs in your Documents using folders.VERSIONS FROM HISTORY AND VERSION COMMENTS
You can now create a Version from any point in history without having to restore that history point first. You can also create intermediate Versions before existing Versions. Comments can also now be added to existing Versions to document your designs better.FEATURE DIAGNOSTICS
Onshape will now highlight on screen where a feature is failing to help you diagnose what's wrong.RESTORE SKETCH
If you press the X button on the sketch dialog to cancel the sketch without saving any changes, a new popup message appears at the top of the Document for 10 seconds, giving you the opportunity to restore the changes to the sketch if you pressed the X button by mistake. Once the message disappears, the sketch will remain as it is.DRAWINGS
- Flip dimension arrows - arrows on linear, radial and angular dimensions can now be flipped by clicking the orange dot on the arrowhead.
- Explode notes - you can now convert notes on Drawings into Polylines. This is useful when you need to export a drawing to older 2D CAD software or machine controllers that do not support note entities. Select a note, right-click and select Explode.
- Link dimension property to Drawing value - by default all dimension properties, like the number of decimal places, are linked to the values set in the Properties dialog unless you manually override them with some other value. After a manual modification, you can now link a dimension back to the value in the Properties dialog and any subsequent changes to those values will update the dimension. Simply select the value with (Drawing) next to it to link the value back to the Properties dialog.
- Export Drawing templates - you can now export an Onshape Drawing in DWT format to quickly create a custom drawing template. Sheet 1 of your drawing will be the primary template and Sheet 2 will be the continuation template. Right-click the Drawing tab and select Export.
- Images in templates and exported DWG files - images added to a drawing are now included when exporting to DWG or DWT format.
- Feet and inches in custom templates - you can now create new custom drawing templates in feet and inches.
FEATURESCRIPT
- Collaborator name added to cursor - whenever another person makes an edit in a FeatureScript tab, a small popup will appear next to the cursor with the name of the person making the edits. This makes it much easier to determine which user is making edits if there are several people working on the code at the same time.
- Remember previous search terms - in the search tool within a FeatureScript tab, a drop down arrow next to the search box lists all previous search terms, making it easier to find strings of text over and over again.
- New queries:
qFarthestAlong - a query for the entity farthest along a direction in world space.
qParallelPlanes - a query for all planar face entities parallel to a plane or normal to a vector.
qWithinRadius - a query for all entities within a specified radius from a point.
qIntersectsLine - a query for all entities touching a specified infinite line.
IMPORT FEEDBACK
Several improvements have been made to the import and notification dialogs, including the import tab in the Document, to make it easier to determine whether a file has been translated on import. Imported zip files now list their contents and guidance notes are provided to explain which formats are supported.ENVIRONMENT PROFILE SETTINGS
You can now store hardware-specific graphics preferences for different combinations of computer and browser. This is useful if you have a computer with a high pixel density display and you want to use a lower resolution for better performance. You can let Onshape determine the best setting for you or you can force or disable high pixel density support. Go to Manage Account, then Preferences.Remember: The updates listed here are now live for all users when creating new documents and over the next few days these features will also be available in documents created before the date of this update.
3
Plus tab folders, I love you.
And TAB folders in same update!
Once again, thanks for listening.
Thanks for every single update. This is a fantastic set up updates. I really appreciate the Likes/Links/Copies! Thanks for such a quick turn around on my request. Now...off to establish myself as the best Onshape designer!!!
Thanks for the updates.
Thanks a lot for the great updates!
Just curious. On the fillet fail I'm wondering why the selected edge was a problem? (The first example before even hitting play on the video.) The selected problem edge looks very similar to the yellow highlighted edges on either side of it that presumably its happy with.
Cheers Owen S.
Perhaps a future version could evaluate the entities one at a time and set good to green, and bad to red?
Thanks, Owen S.
Tab folders are great but I really dislike that the folder opens/expands when I drag and drop a tab into it.
I would much prefer that the folder stays closed until I decide to open it.
Thanks
_Ðave_
Linked[in]
Incredible work as always! You guys are awesome!
I'm really enjoying Onshape at the moment !
+1
Having said that, I really enjoy the concept and I find my working efficiency has improved because of the logical storage design approach. I now file in the following order:
Top Level Assembly
Parts
Sub Assemblies
Fasteners
Drawings
Research Data
