Multiple use for imported parts
Dylan_StewartDylan_Stewart Member, Developers Posts: 107 PRO
Okay, I'm going to try and explain this to the best of my ability (<--Feel like I've said that before?? :/)
So I have a profile that I am importing in to a FS..... easy enough...
Then, I turn it in to a function.
export enum sealantProfileID
    annotation { "Name" : "1/16 inch" }
    F72Dq47pUtYbudg_0,
    annotation { "Name" : "1/8 inch" }
    Fe9DDixnU9zeHn2_0,
    annotation { "Name" : "1/4 inch" }
    FCofrjEa8xpUaY3_0
export function evsealantProfileID(value is sealantProfileID)
    return {
                "F72Dq47pUtYbudg_0" : .0625 * inch,
                "Fe9DDixnU9zeHn2_0" : .125 * inch,
                "FCofrjEa8xpUaY3_0" : .25 * inch
            }[value as string];
So my question is can I use this to extrude the imported profile PS while using it as a function?
I have tried and I'm not having any luck....
Really, I would like to reduce the amount of options in UI and I thought I might be able to get 2 birds with 1 stone here.
Digital Engineering
    You can use that enum to indicate both a sketch id and an extrude thickness via that function, yes.
    Can you share a document to give us a better idea of what you're trying to do?
  • Dylan_StewartDylan_Stewart Member, Developers Posts: 107 PRO
    Thank you @kevin_o_toole_1
    I got it figured out. I was actually calling the wrong sketch in my FS.....
    Digital Engineering
