Advice on springs. (Not answered)
clayton_ertley
Member Posts: 58 ✭✭
I am working on a nifty little invention for my wife but have run into a wall on deciding how to approach the application of a spring.
The only experience that I have with springs is for my twisty puzzles and even that is just compression springs used to minimize friction.
Which is better for me in this case? Torsion or flat springs?
I have attached an image in order to illustrate my needs.
NOTE: This is quick draft done in MS Paint over a screen shot taken in the early stages of design.
Thank you in advance for any advice!
-Clayton
-Clayton
Torsion spring goes are great, but as you have it shown it is not a good installation. Usually the axis of the spring is concentric with the axis of the pivoting part. If you can't do that in this case then you'd be better off with the leg of the spring more parallel to the face of the pawl. Springs are long life components. The way you have the torsion spring installed would yield wear of the spring tip or a groove in the pawl, plus the tip is usually an imprecise length so you'd have a lot of variation with your spring forces.
(sorry - couldn't resist, the design engineer in me still leaks out from time to time.)
Oh, wait, i see you sitting at your desk
