Image digitise/reference image with scaling
Hi,
I am aware that in solidworks you can import and image and trace around it, you can add a dimension and will scale the entire drawing. Can Onshape do this? I am interested for the purpose of then creating a dxf file for a cnc cutter.
thanks
    Sure, just:
    Import image into document.
    Create new sketch
    Click insert image **
    Draw rectangle
    Use dimension or drag to scale
    Feel free to sketch on top of image
