Newbie stuck with Summerhouse plan
trevor_thornton
Member Posts: 2 ✭
Hi OnShapers - I sat down and started building my design for a Summerhouse in my back garden. All went well until I realised that nearly everything is one huge part - I have a door frame and a working animated door in my Assembly though! I think I can strip out the component walls using SPLIT but cannot get it to "take" - does anyone have a minute to explain if this is possible. If it's a NO I shall go back and redesign properly from scratch. Thanks - Trevor.
https://cad.onshape.com/documents/b5a898c34b683222bf051faa/w/d3684e205a81818701db6740/e/5d0413c29ebb14254ac4f404
3dcad
Member, OS Professional, Mentor Posts: 2,477 PRO
Goto edit your wall extrudes and check 'new' instead of 'add' on top of dialog, you might need to divide some extrude into multiple extrudes if parts are touching each other.
//rami5
