Loft from a non planar surface
david_fisher031
Member Posts: 24 ✭✭
Is it possible to loft from a non planar surface ? I wish to loft from a circle that has been projected up to the curved surface in the image below, is this possible ?
mlaflecheCAD
Member, Onshape Employees, Developers Posts: 193
I presume the circle projected has been split onto the conical surface above, so yes, that can be one of the loft profiles.Regards,Mike LaFleche @mlaflecheCAD5
