How do I reduce the file size of my document if it is view-only? (Free Plan)
it is over 90mb and it only contains two parts?
To the OP: You need to temporarily make your document public, then make a (private) copy of it. The copy will be a lot smaller, because the history is not included. Then you delete the original document to regain the space. Remember to empty the thrash. :-)
