Issues with Assemblies and Sketches
I have been having several issues with this and I need to know if anyone else has had these and would be able to help me out.
First I will start out with the Assembly. I am trying to use a Revolute mate and restrict the rotation to a simple degree. Seems simple enough. I select the limit option and enter 0 degree as my minimum and then enter something like 45 degree for my maximum. Simple right?... well this is until I try to rotate the part only to find that it only rotates in the negative direction. I have tried and tried to correct this and no matter what, it will only rotate in the wrong direction. It will only rotate in the correct direction if I change the orientation of my part by flipping it 180. My part is already in the orientation that I want. Why is my part rotating in the wrong direction? Am I missing something?
My other problem may be something very simple but when in sketch mode, I want to use the fillet tool. I select the tool, select the point I want my fillet and then edit the dimension to get the size I need. NOW, my issue comes into play when I want to add another fillet of a different size, smaller, in another location. There is no option to enter a radius dimension before selecting my point so I get an error saying that the radius is too large for the selected point or something like that. Anyway, how do I add fillets of different sizes in the same sketch, regardless of size, when I can not enter the dimension before hand?
Any assistance or guidance is greatly appreciated. Thanks!!
Having said that we also need to allow negative angle or angle over 360 deg or both to let user choose any range they want and we are working on that. For now as you found changing the alignments or changing the order of selection should allow to limit in desired range by providing a limit in 0-360 deg range in increasing order. User can also drag to see the value of mate degree of freedom to understand the required input. We understand this is not desired workflow and are working on supporting negative angles and provide more aid to understand direction of mate measurement.
1st step:- Mate connector created
2nd step: Flip the primary axis to change direction of rotation.
2nd question answer: You created all fillet by point selection method so all fillet taking same radius value which you entered after first point selection. For adding another fillet of a different size, smaller, in another location you need to create fillet by selecting line method. Kindly refer below video for more detail.
