MM and Inch in the same document?
dustin_allen692
Member Posts: 3 EDU
Hi,
Is it possible to have mm and inch drawing and parts in the same document? I am working on an assignment for a class and I have to draw and dimension parts with both inch and mm measurements in the same assignment.
PeteYodis
Moderator, Onshape Employees Posts: 583
@dustin_allen692 Can you be a little more specific here as your exact needs? Do you need a 2D drawing where some dimensions are in mm and others are in inches?5 -
PeteYodis
@dustin_allen692 Yes your request is more clear now. Usually drawings don't change units from sheet to sheet. That is a bit non-standard. There is a request for each dimension to be able to vary from the drawing level unit setting. The units for the drawing are not at a sheet level.
Currently in Onshape you could make a drawing tab of the part and detail it in inches. You could then make another drawing tab, and set it's units to mm and detail that one. Onshape drawing tabs have their own units, separate from that of the document workspace unit settings.
5
