Automated OAuth Callbacks
Hello,
I've started seeing requests once per minute to both of my OAuth callback URLs (staging and production) as of a few weeks ago. The requests are invalid (missing state parameter), so my server is rejecting them, creating noise in our logs and event tracking.
Given that the requests are coming to both our staging server and our production server, I'm guessing that it's some automated process run by Onshape. The IP address in question is 52.72.1.151, which appears to be an EC2 instance.
Could you confirm whether these requests are coming from an Onshape service? If so, could you provide some insight into the purpose of the requests?
Thanks,
Jason Wadsworth
Thanks,
Jason Wadsworth
The service 'pings' both the OAuth redirect URLs and the Base Href (for integrated applications), it does so with 'plausible' GET requests, however the OAuth state param is one that we don't include when interrogating the OAuth redirect URLs (since the state parameter is not mandatory). If you can send an email to api-support@onshape.com we can work out a resolution.
