How do I delete a rectangle on a sketch?
![bdubu](https://cad.onshape.com/images/placeholder-user.png)
If I select just a side of the rectangle and try to delete it, the other sides remain. If I stretch a selection rectangle around the entire rectangle and delete, it leaves the overall sketch (an outer rectangle which I believe may be a "center defined" rectangle) underconstrained. It's as though the outer rectangle's center point is no longer defined once I've deleted the inner rectangle. Is there a simple way for me to delete this rectangle inside of a rectangle?
