Sharing Custom templates within Onshape.
in Drawings
I know I can email my DWT file to my students and have them import it every time they want to use it, but is there a way to have the DWT shareable?
I suppose I could create an empty "part" with the DWT already loaded as the template for "drawing 1" but sharing the basic DWT or custom template seems like a more flexible solution.
thanks for any ideas.
~Steve
~Steve
Sharing a doc with a team, so they can find the template list sounds fine..
~Steve
This could be good or bad depending on whether the document template is itself a controlled document requiring a revision...
We are continuing to make progress in this area, but I don't expect template update anytime soon. I don't recall seeing any customer requests for associative templates yet. Being able to change the template of an existing drawing would probably come first, for which we have some requests.
-John
With regards to linked templates... Can you explain the need or desire a little bit more for having templates remain attached and potentially have an ability to update drawings spawned from them? I have personally seen some horror stories in that scenario, so I'd like to hear your thoughts and expectations here.
Another issue I often find is change of paper size, hence also the template, is there a way or going to be an easy way to manage this?
Similar scenario to @brucebartlett 's workflow.
Possible scenarios in no particular order for wishing to update the template:-
(a) Marketing department releases new company logo and insists it's on all documentation overnight...
(b) Being new to OS I make a first attempt at a drawing template but come up with a better idea in a few months time.
(c) We move factories and need the address to change and don't want to up revision all the drawings.
(d) I make a quick sketch for a product to use in house but then develop it into something more formal for external use later.
This is low priority for me but it'd be on the "nice to have one day" pile.
One feature that I'd really like is to be able to tell how many documents are referencing a particular template. So if I need to make a radical change to a different new template (not an update tweak to an existing one) I can see what still points to anything obsolete, so I can see what still need to be addressed and to prevent anything slipping through cracks. Possibly similar or incorporated into the new tag system, so a drawing template could be a tag, and we can then view all with that tag.
Cheers,
@brucebartlett We released a sheet size change functionality under properties of the sheet. If you are not able to see this, then submit a ticket and we can help you through it. There is a bug affecting drawings made from older templates not being able to access this new function.
and I still can not seem find the sheet size change function on any of my old drawings, I will however look for it in future new drawings.
