I'm having trouble entering values into text fields in Kiri:Moto. Anyone have experience?
I've only just started using the onshape and Kiri apps but I'm trying to set up for a trial run of motors via a TinyG driver. Under device menu (within kiri) I've selected Any.generic.TinyG. To the right, there's a list of fields that I think should be editable. Specifically, I cannot edit the dimensions 'bed width' 'bed depth' or 'name'. I don't care about the name but it seems to me I should be able to edit the dimensions.
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016
    @greg_robinson305 If you go to the ? menu -> Feedback when in the Kiri app, you can send a ticket to their support and they can give you a hand.
