Cannot Load Workspace
Hi there,
When I try to open OnShape in Chrome I get stuck at loading workspace. Anyone have a similar issue and know any workarounds?
Thanks!
Stephanie
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016 image
    @stephanie_castilla you can try going to https://cad.onshape.com/check and see if your system/connection will work with Onshape.  If that shows all green checks I would use the ? menu -> Feedback to submit a ticket so we can take a closer look.
