import a view drawing to your personal document
hello, this is my first time using Onshape. One of my team mates posted their chassis drawing as view only document, and wanted to make some changes for myself, is there any way to import the view drawing to my private document so I can make some changes.
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015 image
    @roberto_arizabalo If they share it view only (with the copy option) then you can copy the workspace and make a copy you will then be able to change.  Otherwise if you are not shared with a copy option, you cannot change it.
